iGO pentru Samsung S8
Localitate: Constanta
Has thanked: 588 ori
Been thanked: 1750 ori
RCA 2018
#16
Mie Ian 31, 2018 7:35 am
owexonline scrie:
Mie Ian 31, 2018 7:09 am
Se pare ca m-am grabit sa aform ca "merge" , adica functioneaza .
Totul parea ok , pana in momentul in care am avut nevoie de navigatie .
Porneste ok ,arata harta , te plimbi prin setari , DAR .....cand dau "Destinatie" introduc tara , orasul , strada, numarul ..... si dau sa porneasca navigatia ....aplicatia pur si simplu dispare de pe ecran ..
Care ar putea fi cauza ?
Incearca sa pui kitul pe memoria interna, cu totul ocupa max.2,5Gb, din 32/64Gb cat are......Vreau sa spun ca nu ocupa mult.
owexonline
Has thanked: 8 ori
RCA 2018
#17
Sâm Feb 03, 2018 5:42 pm
Revin,
Am sters TOT ce avea legatura cu iGO din telefon si microSD card .
Am copiat kit-ul pus de " lemax55 " , cel car nu contine harti .
Pe microSD am facut un folder "addons" in care am copiat "content" care este populat cu tot ce trebe in fiecare folder .
Am incercat toate adaugarile modificarile posibile care le-am gasit pe net...nicicum nu am reusit sa il fac sa citeasca ce este in content pe microSD.
in sys ( din memoria interna ) am asa:
[device]
devtype_fallback_to_model=1
si :
linked_root_list="/storage/extSDCard/iGO /storage/sdcard2/iGO /sdcard2/iGO /sdcard/external_sd/iGO /ext_card/iGO /mnt/_ExternalSD/iGO /mnt/emmc/iGO /mnt/extern_sd/iGO /mnt/external_sd/iGO /mnt/exsdcard/iGO /mnt/ext_card/iGO /mnt/ext_sd/iGO /mnt/extsd/iGO /mnt/extSdCard/iGO /mnt/sdcard/_ExternalSD/iGO /mnt/sdcard/external_sd/iGO /mnt/sdcard/ExtStorages/iGO /mnt/sdcard/extStorages/SdCard/iGO /mnt/sdcard2/iGO /storage/sdcard1/iGO /storage/sdcard0/iGO /storage/iGO /sdcard/sd/iGO /mnt/sdcard-ext/iGO /mnt/sdcard/sd/iGO /mnt/sd/iGO /mnt/sdcard/iGO /mnt/iGO /sdcard/iGO /storage/sdcard1/iGO /mnt/sdcard1/iGO /mnt/ext/SdCard/iGO /storage/ext/SdCard/iGO /storage/emulated/0/iGO"
has_secondary_root=0
;has_secondary_root=1
;android_secondary_root_path="/storage/extSdCard/addons"
din total commander ,microSD este la : /storage/5600-4884
Va multumesc in avans pt eventualele raspunsuri care sa rezolve problema mea de a avea "content" pe microSD iar iGO in memoria interna
Has thanked: 705 ori
Been thanked: 1924 ori
RCA 2018
#18
Sâm Feb 03, 2018 6:00 pm
@owexonline ai citit postul #10?In sys.txt lasa doar aceasta linie la [folders]
android_secondary_root_path="/storage/5600-4884/addons"
Stergi folderul SAVE.
owexonline
Has thanked: 8 ori
RCA 2018
#19
Sâm Feb 03, 2018 7:40 pm
lexmax55 : MULTUMESC .
am citit toate posturile, inclusiv #10 ....dar abia in #18 ai fost explicit :)
pana acum tot am adaugat , nu m-am gandit ca trebuie sterse liniile vechi .
Acum se pare ca functioneaza . Abia astept sa testez aplicatia la drum
Neme2013
Been thanked: 3 ori
RCA 2018
#20
Vin Feb 16, 2018 7:34 pm
salutare.. la mine pe s8 .. kitul lui lemax55 instalat in memoria interna nu functioneaza, instalez fara probleme insa cand deschid aplicatia vad o secunda "IGO se incarca" dupa care blackscreen si asa moare. va rog daca aveti vreo idee.. nu am modificat nimic in sys.txt doar am adaugat harti.
RCA 2018
#21
Vin Feb 16, 2018 7:43 pm
Ai mai incercat si alt kit?Lasa doar o harta,adauga licenta,sterge folderul SAVE.Kitul a fost testat de colegii de mai sus si este functional.
victorpetroi
Has thanked: 548 ori
Been thanked: 827 ori
RCA 2018
#22
Vin Feb 16, 2018 7:53 pm
@Neme2013 Ai cumva trecut la Oreo? Daca da poti spune adio la iGO Primo. Doar Nextgen mai functioneaza...
Neme2013
Been thanked: 3 ori
RCA 2018
#23
Vin Feb 16, 2018 7:59 pm
victorpetroi scrie:
multumesc de informatie.. am trecut la biscuiti! wtf! Sti vreun nextgen functional pe S8 OREO?
RCA 2018
#24
Vin Feb 16, 2018 8:11 pm
Unii colegi au testat kitul de aici,versiunea 2017>citeste acel topic
https://www.gpszone.ro/viewtopic.php?f=91&t=634
Azkan
Been thanked: 3 ori
RCA 2018
#25
Mie Mar 28, 2018 7:33 pm
Si eu am trecut, din pacate, la Oreo si a "picat" Igo primo.
Am inlocuit cu NextGen by pongo dar se blocheaza. Merg pe Here pana se gaseste vreo varianta.
RCA 2018
#26
Joi Mar 29, 2018 5:15 am
Incearca kitul de iGO NextGen de aici, contine Romania map:
ludovic
RCA 2018
#27
Joi Mar 29, 2018 4:15 pm
Salut ! Multumesc frumos rcv64 pentru kit,e super...Oare cum as putea sa fac sa se vada semnele de circulatie,
si semafoarele? Folosesc harti Here Q4 2017,si in rest,totul e mai mult decat OK.Salutari...
Ultima oară modificat Sâm Apr 21, 2018 3:12 pm de către ludovic, modificat de 2 ori în total.
owexonline
Has thanked: 8 ori
RCA 2018
#28
Lun Apr 16, 2018 9:07 am
Am facut upgrade la OREO 8.0 ...igo nu mai functioneaza .
Se vede cercul de loading o secunda si apoi ecranul ramane negru .
RCA 2018
#29
Lun Apr 16, 2018 1:59 pm
iGO primo nu mai functioneaza pe Oreo, trebuie instalat iGO NextGen, ai un kit functional la postul #26...
owexonline
Has thanked: 8 ori
RCA 2018
#30
Lun Apr 16, 2018 6:02 pm
rcv64 : functioneaza in sensul ca programul ruleaza. am sa il testez in trafic .
Am modificat sys si am toate chestiile mari pe microSD :)
pe cand m-am obisnuit cu meniul de la primo ......:)))
