Actualizare harti Renault Megan 3 TOMTOM Carminat/Carminat LIVE
florinsz
RCA 2018
Mar Ian 10, 2017 3:34 pm
Buna as dori daca se poate un tutorial de unde si cum descarc si instalez harti pe o navigatie Renault Megan 3.Va Multumesc.
tbebe
Been thanked: 4 ori
RCA 2018
Mar Feb 28, 2017 10:33 pm
Step 1 : Make a backup of your Original SD Card !!
Step 2 : Copy your backup on your new SD Card
Step 3 : Always on your new SD Card, Delete your Old Map and delete "loopdir" folder, like this :
Step 4 : Create a folder at the root of your new SD Card, named the folder "the name of your new map" for example, France or Europe
Step 5 : Copy all downloaded new map files in your new folder at the root of your new SD Card
Step 6 : Create a text file at the root of your new SD Card, named the text file "ttgo.bif" -- NO "ttgo.bif.txt"
Step 7 : Edit the text file "ttgo.bif" you just created and write in this : (FOREMOST)
Code:
DeviceName=Carminat TomTom
DeviceUniqueID=XXXXXXXXXX ( Your Unique Device ID with no spaces)
ApplicationVersionVersionNumber=8841 (Your Current navcore version)
Step 8 : Download LAST FastActivate Prenium ([Only Registered Users Can See Links. Click Here To Register]) and copy FastActivate.exe at the root of your new SD Card
Step 9 : Run FastActivate.exe
1) Click on "Update Meta.txt"
2) Click on "ttsystem/PNDNavigator"
3) Click on "Maps/Voices/Speedcams"
Step 10 : Put your new SD Card in the Carminat TomTom And Run your car.
Caesar
Has thanked: 15 ori
Been thanked: 12 ori
RCA 2018
Vin Mar 03, 2017 2:14 pm
Salut
Am urmat si eu pasii de mai sus
Totul ok pana la
unde da eroare ttsystem/PNDNavigator" - "file missing".
Am scos cardul l-am introdus iar in cititor si am dat doar 2) Click on "ttsystem/PNDNavigator"
dar la fel cu eroare
O sugestie?
Merci
PS: am conectat cardul asa la GPS si acum am eroare "you cannot use this map Europe 101062 on this device"
nu este harta pt Carminat? o alta versiune de unde?
ttgo.bif file contents:
[TomTomGo]
DeviceName=TomTom Carminat LIVE
DeviceVersionHW=beaumont
DeviceSerialNumber=IB3172JXXXXX
SDCardId=
DeviceUniqueID=AK7HA XXXXX
RamDiskVersion=20140626
BootLoaderVersion=839378
LinuxVersion=1574740
ApplicationVersionVersionNumber=9884
ApplicationVersion=1609031.550
UserLanguage=English UK
Dan
Has thanked: 77 ori
Been thanked: 101 ori
RCA 2018
Vin Mar 03, 2017 3:43 pm
Din ce stiu eu, nu mergeau cele cu Carminat LIVE ci doar cele cu Carminat, si cu app version maxim 8842, poate intre timp s-a rezolvat ceva si cu cele LIVE si nu stiu eu ... as fi curios sa aflu, daca stie cineva ceva.
serjgh
RCA 2018
Vin Mar 03, 2017 4:44 pm
Cica a probat cineva pe LIVE si nu merge.
tanaru81
RCA 2018
Mar Apr 11, 2017 4:55 am
salut,ma poate ajuta si pe mine cineva?de unde aflu ce versiune de navigatie am?
tanaru81
RCA 2018
Vin Apr 14, 2017 7:31 am
Deci exista alte solutii in afara celor oficiale de a pune harti pe caraminat live?Sunt anunturi cu carduri care se vand si pentru caraminat live!
nicuaab
RCA 2018
Vin Mai 19, 2017 8:33 pm
tanaru81 scrie:salut,ma poate ajuta si pe mine cineva?de unde aflu ce versiune de navigatie am?
Scoti sd-cardul din navigatorul masinii si il pui in PC apoi il deschizi si gasesti acolo un dosar numit ''loopdir'' si in el un fisier ''loopback.ex3'' pe care il deschizi cu notepad. O sa se deschida mai greu dar o sa se deschida si o sa gasesti in el informatii despre navigatorul tau. Cauta cu atentie. Eu cel putin asa am procedat. Succes!
Renault Scenic 3 - 2011
tanaru81
RCA 2018
Sâm Mai 20, 2017 6:49 am
insa ai reusit sa pui harti sau altceva?
nicuaab
RCA 2018
Joi Mai 25, 2017 7:03 pm
Caesar scrie:Salut
Totul ok pana la
O sugestie?
Merci
[TomTomGo]
SDCardId=
Pana la urma ai rezolvat problema? Cum ? Eu am parcurs toti pasii cu brio dar cand pun cardul in navigator imi zice acelasi lucru "you cannot use this map Europe 101152 on this device"
Dan
Has thanked: 77 ori
RCA 2018
Vin Mai 26, 2017 5:27 am
nicuaab, ce versiune de bootloader ai ?
nicuaab
RCA 2018
Vin Mai 26, 2017 1:58 pm
BootLoaderVersion=80055
Dan
Has thanked: 77 ori
RCA 2018
Vin Mai 26, 2017 2:45 pm
nicuaab scrie:BootLoaderVersion=80055
si navcore ? scuze ca am uitat sa intreb.
nicuaab
RCA 2018
Vin Mai 26, 2017 8:18 pm
ApplicationVersionVersionNumber=8842
nicuaab
RCA 2018
Sâm Mai 27, 2017 9:22 pm
Ceva nu fac bine. La punctul 3 de la pasul 9, ''patch maps,voice,speedcams'' , am o eroare cu ''incomplete maps'' care arata cam asa:
..:: FastActivate 04/23/2017 ::..
________________________________________________________________________________
Voice(s):
data71.chk => .dct OK
data72.chk => .dct OK
data97.chk => .dct OK
Complete Map(s):
Incomplete Map(s):Europe-101151.meta => .dct ERROR
Fuel prices:
Speed cameras:
BIF File......H:\TTGO.BIF
KeyGen Type...8
Device Name...Carminat TomTom
Application...8842
Bootloader....80055
DeviceID......AK6ZUC2GA6
Storage.......Size 7687MB, Free 4406MB
Press any key to continue ...
Am incercat cu mai multe harti si la fel.
Ma poate lumina si pe mine cineva .
