Harti RNS 315
bma26
RCA 2018
#796
Lun Apr 30, 2018 7:29 am
chelnov scrie:
Mar Apr 24, 2018 2:46 pm
da corect.......dar eu prefer sd nu micro sd.....dar oare stie despre ce este vorba?adica are tot cei trebe?ca parola i dam
La laptop am slot pentru card sd( nu micro sd), card urmeaza sa cumpar, dar nu stiu cat de pare trebuie sa fie. Cu partea de deblocare cred ca o sa ma descurc, dar o sa mai am nevoie probabil de parola. Daca e cineva dispus sa " se ocupe " de mine putin, i-asi fi foarte re unoscator :D
rioachim
Been thanked: 18 ori
RCA 2018
#797
Lun Apr 30, 2018 9:35 am
Vezi ca ai nevoie de un laptop vechi de vreo 10ani, iar hartile sunt oricum vechi, ti-am trimis demult un mesaj privat de ce nu prea merita sa te agiti.
florin84
RCA 2018
#798
Vin Mai 04, 2018 9:09 am
buna, are cineva din cluj sd card cu europa de est pentru rns 315?
alinutz198
RCA 2018
#799
Vin Mai 18, 2018 10:12 am
si eu am reusit, dar acum nu pot reface sd cardul.
nu merge deloc sa il deblochez.
am incercat
lubuntu 16.04 32bit with patched kernel for mmc (unlocking sd)
needed: suitable card-reader with pci connection (no usb dongles)
no maps included, unlocking system only!
boot into live system. open terminal. check kernel (uname -r should give you "4.4.98-mmc).
go on with the following tools which can be found on the internet for free: sdinfo, mmc32, cmd42
get infos about a card: sudo sdinfo /dev/mmcblk0
set cid: sudo mmc32 prog_cid /dev/mmcblk0 5d53424c32424d31013917ca53010400
lock card: sudo mmc32 lock_sd /dev/mmcblk0 C99A20843ED7D90B6801E49F2BC80277
unlock card (erases the card!): sudo cmd42 "" "asc" e /dev/mmcblk0
look in "/home/" for the kernel packages (needed for installing a system)
incearca asa:
open terminal
cmd42
(eu am primit command not fund)
sudo -s
sudo echo [erase] /sys/bus/mmc/devices/mmc0*/lock
dupa care apare [erase] /sys/bus/mmc/devices/mmc0:8375/lock
dupa pasii astia mie mi-a vazut cardul in windows si l-am formatat.
sudo cmd42 "C99A20843ED7D90B6801E49F2BC80277" "asc" e /dev/mmcblk0
Am gasit solutia de deblocare in ubuntu cu kernelul modificat:
comanda
sdinfo ( va afisa informatii despre card si specificatia "LOCKED" apoi
sudo cmd42 "C99A20843ED7D90B6801E49F2BC80277" "asc" e /dev/mmcblk0 (intre ghilimele e codul de blocare aferent cidului clona samsung, daca a fost blocat cardul cu alt cod se va introduce acela
SE SCOATE CARDUL DIN CITITOR
se cupleaza cardul din nou si se da sdinfo din nou si trebuie sa afiseze UNLOCKED
alinutz198
RCA 2018
#800
Vin Mai 18, 2018 10:13 am
un pass pentru
cid 41343253443136473042df363c00f501
b77eru
RCA 2018
#801
Sâm Mai 19, 2018 11:34 am
Va salut.
Am un rns 315 eu, 3C0 035 279 cu SW 0007 HW 04 31/10
MAC: 00:26:7E:2E...
2 intrebari
se poate un link cu firmware mai nou? linkul de la pg. 38 nu imi merge.
are bluetooth? am citit ca daca MAC era 00:00.. nu are, la al meu vad ca este scris.
multumesc anticipat.
mark21
Been thanked: 8 ori
RCA 2018
#802
Joi Iun 07, 2018 6:15 am
da, se poate firmware mai nou
da, are BT
speed
Has thanked: 64 ori
Been thanked: 40 ori
RCA 2018
#803
Joi Iun 07, 2018 9:50 am
b77eru scrie:
Va salut.
MAC: 00:26:7E:2E...
2 intrebari
Linkul functioneaza,mai incearca
bavarezul13
RCA 2018
#804
Sâm Iun 09, 2018 7:02 am
Salut! Am cumpărat un card cu navigația gata, l-am instalat fără probleme pe mașină. Acum vreau să-l bag în pc și să rescriu cid ca să pot folosi cardul și pentru a instala harta și pe altă mașină. Cardul nu este văzut nici în Windows, nici în Ubuntu. Probabil este blocat și trebuie deblocat. Cum se face asta? Dacă nu, se poate instala harta și pe altă mașină, fără să schimb cid?
liviulucian
Has thanked: 11 ori
Been thanked: 30 ori
RCA 2018
#805
Sâm Iun 09, 2018 9:46 am
poti sa faci orice doresti ... sunt valabile toate variantele . Trebuie doar sa citesti putin aici pe topic .
ObiDanKenobi
RCA 2018
#806
Mar Iun 12, 2018 1:36 pm
bavarezul13 scrie:
Uita-te ce CID are, daca este cel de la inceputul treadului nu trebuie sa il schimbi, trebuie doar sa stergi cardul si sa scrii continutul si sa ii dai lock cu parola de acolo. dupa ce ai dat lock poti sa il folosesti pe alta masina
rioachim
RCA 2018
#807
Mar Iun 12, 2018 8:17 pm
Iar daca ii faci un Temporary Lock pe bitii din CSD cu urmatorul tool, inainte de a il bloca efectiv cu parola pt CID, nu se va mai asocia cu masina si il vei putea folosi pentru instalare la oricate RNS315 vrei:
https://github.com/BertoldVdb/sdtool
bavarezul13
RCA 2018
#808
Mie Iun 13, 2018 7:23 am
ObiDanKenobi scrie:
bavarezul13 scrie:
Nu pot sa-l deblochez. Rulez ubuntu modificat din prima pagina, rulez comenzile specificate:
sudo -s
echo erase> /sys/bus/mmc/devices/mmc0*/lock
dupa aceasta a doua comanda imi apare Connection timeout. Ma duc pe card si cand deschid fisierul lock, scrie "unlocked", dar daca il scot si il bag iar, am din nou "locked". Daca vreau sa inchid terminalul imi spune ca inca e un proces activ.
Bogdan074
Been thanked: 16 ori
RCA 2018
#809
Mie Iun 13, 2018 12:56 pm
rioachim scrie:
Poti te rog sa descrii procedura
rioachim
RCA 2018
#810
Mie Iun 13, 2018 6:54 pm
Descarci pe linux sdtool ( https://github.com/BertoldVdb/sdtool/ra ... d64-sdtool ), apoi
sudo ./amd64-sdtool /dev/mmcblk0 lock
inainte de
sudo ./mmc64 lock_sd /dev/mmcblk0 [PWD]
Ultima oară modificat Mie Iun 20, 2018 10:15 am de către rioachim, modificat de 3 ori în total.
