Probleme iGO Nextgen
mincueduardionut
RCA 2018
Sâm Iul 01, 2017 9:52 am
Salut!Am un igo nextgen israel,il am pe card sd si apare o problema.Cum il pot baga pe card?[img]
[/img]
Am android 6.0
Localitate: Constanta
Has thanked: 661 ori
Been thanked: 1912 ori
RCA 2018
Sâm Iul 01, 2017 10:53 am
mincueduardionut scrie:Salut!Am un igo nextgen israel,il am pe card sd si apare o problema.Cum il pot baga pe card?[img]Screenshot_20170701-124844.png[/img]
Am android 6.0
Nu este corecta calea catre folderul iGO_Israel de pe card. Instaleaza total commander si vezi denumirea exacta a cardului si o introduci in linia folders din sys. Din eroare reiese ca ar trebui sa introduci urmatoarea linie:
data_folder_name="iGO_Israel"
linked_root_list="/storage/C89D-CC06/iGO_Israel /storage/MicroSD /extsd /storage/extsd0 /mnt/extsd0 /mnt/storage/extsd0 /external_sd0/mnt/sdcard/external_sd0 /mnt/external_sd0 /mnt/sdcard/external_sd /sdcard2 /sdcard /sdcard/sd /mnt/sdcard /mnt/sd /mnt /storage /mnt/extSdCard /mnt/external_sd /mnt/sdcard/external_sd /sdcard/external_sd /storage/extSdCard"
mincueduardionut
RCA 2018
Sâm Iul 01, 2017 11:39 am
Il am acum pe card iGO_Israel,asa scrie la card C89D-CC06,Nu trebuie sa mai mut nimic?
mincueduardionut
RCA 2018
Sâm Iul 01, 2017 11:46 am
Am copiat tot fragmentul acela in sys si face la fel.
RCA 2018
Sâm Iul 01, 2017 1:47 pm
mincueduardionut scrie:Am copiat tot fragmentul acela in sys si face la fel.
Inlocuieste in linia folders din sys cu asta:
;android_secondary_root_path="/storage/extSdCard/addons"
;data_folder_name="iGO_Basar"
;data_folder_name="iGO_Israel"
;has_secondary_root=1
linked_root_list="/storage/C89D-CC06 /storage/emulated/0 /storage/MicroSD /extsd /storage/extsd0 /mnt/extsd0 /mnt/storage/extsd0 /external_sd0/mnt/sdcard/external_sd0 /mnt/external_sd0 /mnt/sdcard/external_sd /sdcard2 /sdcard /sdcard/sd /mnt/sdcard /mnt/sd /mnt /storage /mnt/extSdCard /mnt/external_sd /mnt/sdcard/external_sd /sdcard/external_sd /storage/extSdCard"
Ai verificat cu total commander instalat din google play denumirea cardului ?
mincueduardionut
RCA 2018
Sâm Iul 01, 2017 2:36 pm
Tot la fel apare aceeasi eroare când intru în el de pe card
mincueduardionut
RCA 2018
Sâm Iul 01, 2017 6:26 pm
Pana la urma nu mai apare acea eroare deoarece am sters un fisier igo.version dar nu se păstrează setările adica mereu când intru trebuie sa să fac aceleasi setări generale.Ce pot fac?
RCA 2018
Dum Iul 02, 2017 5:10 am
mincueduardionut scrie:Pana la urma nu mai apare acea eroare deoarece am sters un fisier igo.version dar nu se păstrează setările adica mereu când intru trebuie sa să fac aceleasi setări generale.Ce pot fac?
Inceraca :
data="/storage/C89D-CC06/iGO_Israel"
mincueduardionut
RCA 2018
Dum Iul 02, 2017 9:10 am
Din pacate tot nu merge am incercat 2 variante
Am incercat da sa scot din folderul license fisierul device.nng pe card dupa aceea in folder-ul
Dar tot nu se păstrează setările.Nu se formeaza folder-ul save.
Igo_Israel
RCA 2018
Dum Iul 02, 2017 9:22 am
mincueduardionut scrie:Din pacate tot nu merge am incercat 2 variante Screenshot_20170702-120416.pngScreenshot_20170702-115800.png
Pe ce telefon il folosesti, ca ar mai fi metoda softul pe memoria interna si hartile pe card.
mincueduardionut
RCA 2018
Dum Iul 02, 2017 10:24 am
Am Samsung Galaxy J5 2016,android 6.0,cum se aplica metoda hărți pe card?
RCA 2018
Dum Iul 02, 2017 1:07 pm
mincueduardionut scrie:Am Samsung Galaxy J5 2016,android 6.0,cum se aplica metoda hărți pe card?
Deci la A5 2016 am facut astfel:
-am luat kitul de iGO_NextGen si l-am instalat cu harta Romaniei pe memoria interna
-am creat pe card un folder numit addons iar in interior am copiat tot folderul content (va ramane si in kitul de baza) din kitul instalat in memoria interna in care am adaugat alte harti si poi care m-au interesat
-la linia folders din sys am adaugat:
android_secondary_root_path="/storage/6CF4-3394/addons"
atentie la denumirea cardului, in final linia folders arata asa:
linked_root_list="/storage/extSDCard/iGO /storage/sdcard2/iGO /sdcard2/iGO /sdcard/external_sd/iGO /ext_card/iGO /mnt/_ExternalSD/iGO /mnt/emmc/iGO /mnt/extern_sd/iGO /mnt/external_sd/iGO /mnt/exsdcard/iGO /mnt/ext_card/iGO /mnt/ext_sd/iGO /mnt/extsd/iGO /mnt/extSdCard/iGO /mnt/sdcard/_ExternalSD/iGO /mnt/sdcard/external_sd/iGO /mnt/sdcard/ExtStorages/iGO /mnt/sdcard/extStorages/SdCard/iGO /mnt/sdcard2/iGO /storage/sdcard1/iGO /storage/sdcard0/iGO /storage/iGO /sdcard/sd/iGO /mnt/sdcard-ext/iGO /mnt/sdcard/sd/iGO /mnt/sd/iGO /mnt/sdcard/iGO /mnt/iGO /sdcard/iGO /storage/sdcard1/iGO /mnt/sdcard1/iGO /mnt/ext/SdCard/iGO /storage/ext/SdCard/iGO /storage/emulated/0/iGO"
Ce-i cu galben in folders trebuie modificat de tine.
mincueduardionut
RCA 2018
Dum Iul 02, 2017 1:35 pm
Deci,fac un folder addons pe card si in el bag doar content-ul cu toate in el,dupa aceea instalez apk-ul,si il incerc?Trebuie sa tin mereu content-ul din memoria interna?
RCA 2018
Dum Iul 02, 2017 1:38 pm
mincueduardionut scrie:Deci,fac un folder addons pe card si in el bag doar content-ul cu toate in el,dupa aceea instalez apk-ul,si il incerc?Trebuie sa tin mereu content-ul din memoria interna?
Da, contentul din memoria interna nu se sterge, se poate subtia, mai stergi dem, speedcam, building, skin.....lasi o singura voce, o singura limba, o singura harta, un singur poi.
mincueduardionut
RCA 2018
Dum Iul 02, 2017 6:14 pm
L-am rezolvat,multumesc mult.Am un loading cu Romania si trebuie sa il bag in folder-ul ux dar nu porneste,poate sa fie de la the skin.zip din ux,daca l-as scoate ar fi chel soft-ul
Înapoi la “iGO NextGen Android”
