Va salut !
Ce versiune android de iGO se potriveste pentru Xperia Z5 (rezolutie display 1080 x 1920)?
Am instalat iGO Primo 9.6.7.281004_thin_1.0_JB_sound_fix_IMEI_sys_not_ch anged.apk (not scan IMEI).apk dar receptionez urmatoarea eroare:
"User interface resolution [1776 x 1080] is not supported or compatible skin can not be found. exiting apllication.
Am adaugat in sys.txt urmatoarele linii, dar tot nu ma ajuta:
[rawdisplay]
;driver=engine
screen_xy="1776_1080:1776x1080/1080x1776:fullscreen
Multumesc de ajutor!
iGO pe Xperia Z5
- Been thanked: 4035 ori
Incearca kitul de aici, cu instalare din memoria interna, contine Romania map
https://dailyuploads.net/qyq3zw5esx64
