Instaleaza din magazin play total commander si vezi exact denumirea cardului...si inlocuieste denumirea in
data="/sdcard/iGO"
Am facut exact dupa instructiuni ; atasez un print cu sys.txt
Asa se vede cu Total Commander denumirea ,,Card SD" am incercat si cu :[folders]
Sterge prima linie din sys, [device].....si adauga linia:turbojet scrie: ↑Mar Dec 12, 2017 4:41 pmAm facut exact dupa instructiuni ; atasez un print cu sys.txt
https://i.imgur.com/nDczKgr.png
Tot la fel se comporta; am uitat sa specific sistemul de operare al tabletei este Nougat 7rcv64 scrie: ↑Mar Dec 12, 2017 5:00 pmSterge prima linie din sys, [device].....si adauga linia:turbojet scrie: ↑Mar Dec 12, 2017 4:41 pmAm facut exact dupa instructiuni ; atasez un print cu sys.txt
linked_root_list="/storage/extSDCard/iGO /storage/sdcard2/iGO /sdcard2/iGO /sdcard/external_sd/iGO /ext_card/iGO /mnt/_ExternalSD/iGO /mnt/emmc/iGO /mnt/extern_sd/iGO /mnt/external_sd/iGO /mnt/exsdcard/iGO /mnt/ext_card/iGO /mnt/ext_sd/iGO /mnt/extsd/iGO /mnt/extSdCard/iGO /mnt/sdcard/_ExternalSD/iGO /mnt/sdcard/external_sd/iGO /mnt/sdcard/ExtStorages/iGO /mnt/sdcard/extStorages/SdCard/iGO /mnt/sdcard2/iGO /storage/sdcard1/iGO /storage/sdcard0/iGO /storage/iGO /sdcard/sd/iGO /mnt/sdcard-ext/iGO /mnt/sdcard/sd/iGO /mnt/sd/iGO /mnt/sdcard/iGO /mnt/iGO /sdcard/iGO /storage/sdcard1/iGO /mnt/sdcard1/iGO /mnt/ext/SdCard/iGO /storage/ext/SdCard/iGO /storage/emulated/0/iGO"
has_secondary_root=0
Colegul, incearca kitul asta, cu instalare de pe card, nu contine map si poi.turbojet scrie: ↑Mar Dec 12, 2017 5:13 pmTot la fel se comporta; am uitat sa specific sistemul de operare al tabletei este Nougat 7rcv64 scrie: ↑Mar Dec 12, 2017 5:00 pmSterge prima linie din sys, [device].....si adauga linia:turbojet scrie: ↑Mar Dec 12, 2017 4:41 pm
salut ma poti ajuta si pe mine la instalarea igo pe un samsung j3 2016?evemtual daca imi dai un video tutorialnina scrie: ↑Sâm Ian 21, 2017 9:55 amUn kit care se poate pune direct pe card sau memoria interna indiferent de aparat fara a se pierde setarile. La prima pornire va da un mesaj de eroare,dati O.K. si dupa aceea va functiona fara probleme. Kitul are tot ce-i trebuie doar sa-l completati cu harti si poi. Puteti pune harti si poi in folder addons/content separat cu modificarea denumirii corecte a cardului in sys in linia
has_secondary_root=1
android_secondary_root_path="/storage/CARD/addons"
addons="/storage/CARD/addons"
unde cuvantul CARD il redenumiti conform aparatului. Pentru a va fi mai usor la innoirea hartilor puteti pune in kit harti Here si in addons TomTom. Folderul addons poate fi folodit in comun si de Nextgen
salut am instalat igo si am.si hartile 2017 decarcate dar cand deschid igo imi zice global_cfg not found. de la ce sa fie? in folderul de la global_cfg nu am nici un fileAdiCampianu scrie: ↑Lun Feb 20, 2017 3:08 pmBuna ziua si multumesc pentru igo in primul rand
L-am instalat pe un tablet samsung tab 3 lite (in memoria interna) cu addons pe card
Merge foarte bine dar cand caut locuri in jurul cursorului le gaseste dar in momentul cand calculeaza ruta incepe sa mearga mai greoi dupa care scrie ca memoria este incarcata si ceva de ajustat in configurarea rutei
Atat pe tablet cat si pe card mai este destul spatiu
Multumesc din nou
O zi buna
Buna Dimineața ,stefanstnc scrie: ↑Dum Noi 19, 2017 7:09 amBuna dimineața,
Ma numesc Ștefan, vreau sa va mulțumesc pentru tot volumul de informație care se găsește aici ,va rog, dacă puteți sa ma ajutați cu un kit IGO pentru un telefon HTC610 desire, am încercat toate kiturile care se pot pune pe cardul de memorie dar nu reușesc.
Va mulțumesc.
Incearca asa, igo pe memoria interna si hartile pe card, astfel:detonate scrie: ↑Mie Dec 27, 2017 6:10 pmAm un telefon Samsung Galaxy S7 cu versiune de soft 7.0. Telefonul are root facut.
Vreau sa pun toata europa pe card, se poate?? Am incercat fel de fel de variante, nu vrea decat in memoria telefonului. Imi da mereu global_cfg not found.
Ma poate ajuta cineva? Am citit toate postarile dar vad ca nu a confirmat nimeni daca ii merge de pe card. Mentionez ca, cardul meu il vede asa: 3FD1-4B6B si cred ca aici e problema in fisierul sys.txt
E un card de clasa 10, de la SanDisk de 128 gb.
