Va salut dragi colegi. Am o dilema ...
Cum setam luminozitatea la maxim la aparatele noi becker pe care am pus igo primo ?
am incercat toate variantele cu [power] in sys.txt.... nu am reusit, merge dar cu luminozitate scazuta.
Probleme luminozitate igo primo pe becker 6
- alex1963
- Has thanked: 1309 ori
- Been thanked: 947 ori
La unele modele am pus in sys :
[power]
backlight_manage_values = 1
backlight_manage_keys = 1
backlight_max = 8
backlight_min = 1
backlight_reverse = 0
backlight_key_timeout_BA = "BatteryTimeout"
backlight_key_timeout_AC = "ACTimeout"
backlight_key_ontap_BA = "BacklightOnTap"
backlight_key_ontap_AC = "ACBacklightOnTap"
backlight_key_on_BA = "OnOff"
backlight_key_on_AC = "ExtOnOff"
backlight_methods = 39
backlight_events = 1
battery_warning_limit=20
battery_warning_repetition=1
skip_resume_process=1
skip_suspend_process=1
powermgm_state="0"
backlight_day="100"
backlight_night="100"
[power]
backlight_max = 8
backlight_min = 1
powermgm_state="0"
backlight_day="100"
Am reusit dupa ce m-am chinuit sa citesc o postare din forumul vechi (se deschide foarte greu).
Setarile de luminozitate (power) pot fi diferite de la aparat la aparat. Cel mai sigur puteti proceda astfel.
Copiati in PC arhiva DATA.zip din softul original al becker aflat pe flash, dezarhivati si in /DATA/config/devices gasiti fisierul becker_BDC00.ini. Acesta contine setarile de luminozitate, tmc, gps, gestionare memorie, setari tts, etc.
De aici copiati ce tine de [power] si adaugati in sys.txt al igo primo.
Succes!
P.S: In cazul meu au fost:
[power]
auto_backlight=0
backlight_max = 100
backlight_min = 1
backlight_methods = 14
backlight_events = 1,2
skip_suspend_process_all=1
use_power_notification_poll_for_suspend_time=1
disconnect_gps_on_suspend=0
powermgm_state="0"
use_poweroff_on_shutdown=1
sdcard_remove_onsuspend_ignore=1
handle_power_while_focus_lost=1
battery_low_limits="25, 18"
battery_shutdown_at=10
battery_shutdown_delay=10
Succes!
[power]
auto_backlight=0
backlight_max = 100
backlight_min = 1
powermgm_state="0"
