Becker be j10
- Has thanked: 5 ori
- Been thanked: 4 ori
Salut....stie cineva daca se poate face update de hărți la modelul becker be j10 ?
Mulțumesc anticipat ptr răspunsuri
- Been thanked: 4036 ori
Pe softul original nu poti face update, becker a dat faliment si a oprit updat-urile.
Pe un soft "tratat" poti folosi ultimele harti Here Q4.2019.
salut...ai vre.un link cu asa ceva?...soft "tratat" ? sau procedura cum ar trebui sa fac?
mersi mult
mersi mult
- Has thanked: 11 ori
- Been thanked: 21 ori
Dear Content Manager User,
We would like to inform you that we have created a brand new website for Becker Navigation map updates.
The actual website will be closed sometime in the future, so please be aware that in the future you can access the news, map update information, guides, Content Manager download on this website:
https://contentmanager.welcome.naviextras.com
We will continue releasing updates up to two times a year, granting you the possibility to download the latest available navigation content.
Map updates will be available for purchase in Content Manager at any time, until further notice.
Kind regards,
Content Manager® Support
Kind regards,
Salut...am instalat pana la urma 9.15.3.578281 si am reusit sa instalez hartile q4 2019 dar nu imi vede tot continutul...
Building si Landmarks...Adress Point...Poi Camion...Poi extins...Poi Fuel type...Harta Fsp....Harta fjw
La toate cele enumerate imi da continut inactiv
Speedcam doar daca e txt....si Phonemes eroare generala
Trebuie si alte licente? ca am tot cautat dar nu gasesc nimic
Mersi frumos
sanut....nimeni disponibil cu o informatie la problema mea ?
mersi frumos....dar cu restul cum fac? Building si Landmarks...Adress Point...Poi Camion...Poi extins...Poi Fuel type...Harta Fsp....Harta fjw ? Tot inactive apar....e problema de licenta sau de altceva? Pe iGO Pal nu am problemele astea cu aceleasi licente....tind sa cred ca e ceva din softul Becker
salutare colegi, detin fix acelasi model de becker BE J10 ca si colegiul lucio , dar avand mare nevoie de tmc a trebuit sa revin la softul becker original. zis si facut am luat ultimul soft tratat a lui rcv64 din postul refecut cu button de back doar ca nu reuseste sa imi vada tot continutul (detin hartile 2019,q4) , la adress point vede doar o parte dar mare parte din europa e inactiva, phoname e tot inactiva. Ne poate ajuta cineva cu un set de licente sa functioneze bine cu hartile acestea?
cu softul de la rcv cand porneste softul singura eroare desi nu sunt sigur ca este o eroare ci mai mult un mesaj de intampinare cand deschid aparatul este mesajul: "Avanteq NOT initialized " cu precizarea ca e in apartament aparatul si nu e conectat inca la receptorul TMC , e normal sa apara asa ? sau?
Costi, incearca sa inlocuiesti fisierele tip .dll si cel cu terminatia .con din softul de la mine cu cele din softul original, ar trebui sa dispara eroarea "Avanteq NOT initialized ".
Nu detin aparatul ca sa pot ajusta softul original, doar ce am primit de la colegii din forum....
am incercat fara succes, asta e unu din motive din care am renuntat la softul tratat de mai sus si 2 la mana nu reusesc cu licentele vietii de nici o culoare , ma oboseste gps-ul asta sper sa il vad odata terminat ca plec iar in cursa intr-o saptamana.
daca este un coleg cu un dispozitiv be j10 si are licentele si softul tratat am fi recunoscatori daca ne-ar ajuta putin. Numai bine rau la nimeni
