Speedcam TomTom
Cserrobi
Been thanked: 308 ori
#16
Joi Feb 21, 2019 1:57 pm
-TomTom Official speedcams 2019.02.19.-
Country:
► Show Spoiler
Big thanks Maverick
Cserrobi
#17
Vin Feb 22, 2019 4:27 am
-TomTom Official speedcams 2019.02.21.-
Country:
► Show Spoiler
Big thanks Maverick
lum4n4r3
Has thanked: 7 ori
#18
Mar Apr 23, 2019 1:58 pm
Cserrobi scrie:
Country:
► Show Spoiler
Big thanks Maverick
salut imi poate spune si mie cineva cum se activeaza speedcamera ca nu reusesc de nicio o culoare sa il activez am cautat si nu am reusit , poate aveti vreun tutorial ceva de folosit sau o idee cum se instaleaza cum se activeaza multumesc,
Cserrobi
#19
Mar Apr 23, 2019 3:36 pm
Note: When you extract the radars, you only need to download the relevant speed cams for the maps you place them in and you only need to run FastActivate once for the speed cams, so only need to download the .ov2 and .ver files if the .dct file already exists. So for smaller units can save some space through the whole lot per map doesn't take up much space anyway. If your unit had both the normal and the prem files. When you run it, it only uses Prem for newer units and deletes the normal one. If it does not, then you are using the lower units, so the Prem is an advantage and will use it. When you use your device really and then look at the files, you should know the one (or both) to use - Hope that helps. Obviously, the live units are better anyway, but then you would not be needing this
For example, there is no meta for RU normal, just RU Prem. That is because no Russian has the lower end unit, or there is no meta for it, just the Prem
To make it really simple for you.
eg. if you are in the UK and Ireland and only in the UK and Ireland and have a GO720.......All you need to do once (whenever maps change) run FastActiveate after cut and paste to a file called meta.txt to the root directory
D1 FC EB 24 FC 9B DD 03 E3 16 F2 E2 5C 0A 49 EA United_Kingdom_and_Republic_of_Ireland-101852.meta ; United_Kingdom_and_Republic_of_Ireland 1025_9386
E4 FE 0E 56 C9 74 91 BA EB DA 42 C4 B2 C7 D8 01 Safety_Cam_UK_Premium.ov2 ; Safety Cam UK Premium
E9 E0 AD 81 DB F0 09 13 74 A0 4D 16 5B BE A3 13 Safety_Cam_IE_Premium.ov2 ; Safety Cam IE Premium
The only thing that changes is the map.
When you run the radars.rar file, you only need to download those files relevant to your map/country, not all. The .ver file is only stating the current version. It is not needed. You only need the .ov2 file and overwrite the existing ones. You have to have run FastActive once for a map change. You will have a dct file. That needs to be present obviously.
If you look at the files in your maps relating to speedcams. Having FastActivator and run, check which files have a dct file. Those that do not are the speed cams where there is no meta yet, so are not needed. Those in the map that do not relate to the map can be deleted anyway. If you had a subscription ( you have not since here) TT download the radars file automatically and only insert in the relevant maps. You have to do it manually. You can do this directly via WinRar extract anyway. You only need to download the .ov2 files to the relevant maps
I hope that helps. Regards the Maverick and have a great time and make sure you do not have an accident, as we know, it is never an accident, but stupidity and I have no sympathy for stupid drivers.Sadly there are too many on the road
Extensive coverage in 36 countries across Europe, North and South Americas, Africa, Oceania and Southeast Asia
. Real-time* & twice weekly updates via MyDrive Connect / TomTom HOME
. A community of 3.4 million drivers sharing speed camera reports
*Mobile speed camera locations and real-time updates are only available for devices with active real-time services (e.g. LIVE and TomTom Traffic).
Other devices can download fixed speed camera updates via MyDrive Connect or TomTom HOME.
In France, this service only includes Danger Zones alerts.
euo
Has thanked: 8 ori
#20
Dum Aug 04, 2019 10:15 am
mulțam!
maryus1975
Has thanked: 11 ori
#21
Mie Sep 04, 2019 6:50 am
LINKURILE AU DEVENIT INVALIE,SE POT PUNE ALTELE?MULTUMESC!
Cserrobi
#22
Mie Sep 04, 2019 9:03 pm
reel4ever
Localitate: Sfantu Gheorghe
Has thanked: 153 ori
Been thanked: 198 ori
#23
Vin Sep 20, 2019 1:06 pm
TomTom Official SpeedCams 19-09-2019
https://www105.zippyshare.com/v/SjmyRB56/file.html
Password: navitotal
You will need at least WinRAR version 5.0 to extract the archive
Credit goes to The Maverick
reel4ever
#24
Vin Sep 27, 2019 2:18 am
TomTom Official SpeedCams 26-09-2019
https://www48.zippyshare.com/v/BjXAgci6/file.html
Password: navitotal
reel4ever
#25
Sâm Oct 05, 2019 5:11 am
TomTom Official SpeedCams 03-10-2019
https://www39.zippyshare.com/v/qwDoWNgN/file.html
Password: navitotal
reel4ever
#26
Mie Oct 09, 2019 4:00 pm
TomTom Official SpeedCams 08-10-2019
Download: https://www93.zippyshare.com/v/fXYxSxq8/file.html
Password: navitotal
reel4ever
#27
Joi Oct 31, 2019 3:31 pm
TomTom Official SpeedCams 29-10-2019
Download https://www45.zippyshare.com/v/e1CMVOfJ/file.html
Password: navitotal
Valid21
#28
Vin Noi 01, 2019 9:11 am
are cineva un torrent, ca inebunesc incercand sa descarc de pe link-ul asta...
Has thanked: 730 ori
Been thanked: 2401 ori
Vin Noi 01, 2019 9:16 am
Despre ce link vorbesti ?
Leey
Been thanked: 756 ori
#30
Vin Noi 01, 2019 11:26 am
Valid21 scrie:
vezi acum:
SpeedCams 31-10-2019.rar
(5.16 MiB) Descărcat de 29 ori
Înapoi la “Voci, avertizari si Loquendo”
