igo for Becker and speed camera sounds
eauto
5
Has thanked: 130 ori
Been thanked: 17 ori
Mar Sep 05, 2023 6:10 am
I would like to mute speed cameras on the Becker 7sl but there is no separate control for them. My question : which entry in data is responsible for this and which one could I use in sys
mondo
Has thanked: 315 ori
Been thanked: 84 ori
Mar Sep 05, 2023 9:45 am
[warning]
speedcam_enabled=0
speedcam_warning=0
eauto
5
Mar Sep 05, 2023 1:22 pm
I mean specifically to lower the sound by half, what parameters to set, because there are two zeros.
the reason for my problem is the transport of people, at night when they sleep, the sound wakes them up :)
This sys entry causes the sound to be turned on and off as I understand it. This option exists in navigation.
I need to reduce the volume of the speed camera signal by half
eauto
5
Mar Sep 05, 2023 1:49 pm
in Date there is this entry:
[warning]
is_spoken=0
speedcam_warning=0
speedcam_soundtype=0
speedcam_visualtype=0
speedcam_continuous_approach_beep_when_tonal=0
warn_distances="130:1000,90:690,70:540,50:380,30:230"
approach_beep_distances="115"
speedcam_soundtype_3=1
overspeed_min_speech_repeat_delay=-1
overspeed_min_tone_repeat_delay=16
truck_max_speed_warn=100
use_truck_max_speed_warn=1
speedcam_warn_also_on_invalid_speed_limit=1
speedcam_max_angle=45
speedwarn_toltype=1
speedwarn_alt_toltype=1
speedwarn_alt_builtup_based=1
speedwarn_tolerance_type="fix"
speedwarn_alt_tolerance_type="fix"
I don't know who controls the volume
mondo
Mar Sep 05, 2023 1:55 pm
[warning]
speedcam_soundtype="2"
speedcam_soundtype_0="2"
speedcam_soundtype_1="2"
speedcam_soundtype_10="2"
speedcam_soundtype_11="2"
speedcam_soundtype_12="2"
speedcam_soundtype_13="2"
speedcam_soundtype_14="2"
speedcam_soundtype_15="2"
speedcam_soundtype_16="2"
speedcam_soundtype_17="2"
speedcam_soundtype_18="2"
speedcam_soundtype_19="2"
speedcam_soundtype_2="2"
speedcam_soundtype_20="2"
speedcam_soundtype_21="2"
speedcam_soundtype_22="2"
speedcam_soundtype_23="2"
speedcam_soundtype_24="2"
speedcam_soundtype_25="2"
speedcam_soundtype_26="2"
speedcam_soundtype_27="2"
speedcam_soundtype_28="2"
speedcam_soundtype_29="2"
speedcam_soundtype_3="2"
speedcam_soundtype_30="2"
speedcam_soundtype_31="2"
speedcam_soundtype_4="2"
speedcam_soundtype_5="2"
speedcam_soundtype_6="2"
speedcam_soundtype_7="2"
speedcam_soundtype_8="2"
speedcam_soundtype_9="2"
speedcam_visualtype="1"
speedcam_visualtype_0="1"
speedcam_visualtype_1="1"
speedcam_visualtype_10="1"
speedcam_visualtype_11="1"
speedcam_visualtype_12="1"
speedcam_visualtype_13="1"
speedcam_visualtype_14="1"
speedcam_visualtype_15="1"
speedcam_visualtype_16="1"
speedcam_visualtype_17="1"
speedcam_visualtype_18="1"
speedcam_visualtype_19="1"
speedcam_visualtype_2="1"
speedcam_visualtype_20="1"
speedcam_visualtype_21="1"
speedcam_visualtype_22="1"
speedcam_visualtype_23="1"
speedcam_visualtype_24="1"
speedcam_visualtype_25="1"
speedcam_visualtype_26="1"
speedcam_visualtype_27="1"
speedcam_visualtype_28="1"
speedcam_visualtype_29="1"
speedcam_visualtype_3="1"
speedcam_visualtype_30="1"
speedcam_visualtype_31="1"
speedcam_visualtype_4="1"
speedcam_visualtype_5="1"
speedcam_visualtype_6="1"
speedcam_visualtype_7="1"
speedcam_visualtype_8="1"
speedcam_visualtype_9="1"
speedcam_warning="1"
speedwarn_alt_tolerance="10000"
speedwarn_tolerance="10000"
eauto
5
Mar Sep 05, 2023 2:10 pm
Can you explain to me if this is already a sys entry? with a muted sound?
mondo
Mar Sep 05, 2023 2:24 pm
It is copied to the sys as it is. It is a minimum sound system setting for radar cameras. Not what you wanted?
prodanu
Has thanked: 90 ori
Been thanked: 277 ori
Vin Sep 08, 2023 3:16 am
Just add tts voice, modify sys.txt to speak cameras
[sound]
ding=0
csv_voice_enabled=1
ding_muted=1
Înapoi la “Becker”
