IGO ANDROID PENTRU TABLETA
- mgmm
- Localitate: braila
- Has thanked: 315 ori
- Been thanked: 1810 ori
Salutare tuturor colegilor.
Am o rugaminte...daca detine cineva un kit de Igo functional/testat pentru tableta (eu am o tableta Lenovo tb 7304i) neaparat cu tmc online!Am un kit de nextgen dar la tuneluri se opreste subit iar a doua problema ar fi caracterele prea mici,atasez foto.Momentan am IGO PAL
https://uploadimage.ro/23F9/IMG_20180925_152610.jpg
Nu trebuie sa schimbi programul !!
Pt . oprit in tunel,adauga asta in sys.txt:
[3d]
road_shield=1
tunnel_mode_disable=1
[3d_config]
roadsign_bitmaps=0
rotated_roadsigns=0
tunnel_mode_on_delay=-1
pentru scris mic ...pui valorile de aici:
[rawdisplay]
dpi="170"
screen_xy="auto"
[3d]
road_shield=1
[3d_config]
roadsign_bitmaps=0
rotated_roadsigns=0
[rawdisplay]
dpi="170"
screen_xy="auto"
- mgmm
Mersi mult maistre,il testez si revin!
- mgmm
Din pacate arhiva are erori si nu se poate dezarhiva,nici cu winrar nici cu 7zipcosteld scrie: ↑Vin Sep 28, 2018 7:43 pmSau poti proba kit-ul asta ,cu TMC,radare ,etc !Contine Romania !
instalare in tableta, nu pe card:
https://www120.zippyshare.com/v/1SNSd65A/file.html
- mgmm
[3d]
road_shield=1
[3d_config]
roadsign_bitmaps=0
rotated_roadsigns=0
[device]
devtype_fallback_to_model=1
[android]
has_physical_home_button=0
check_for_dead_links=1
check_folders_after_rebuild=0
wait_for_closing_igo=1
fullscreen=1
tablet=1
asa incepe e ok?
road_shield=1
[3d_config]
roadsign_bitmaps=0
rotated_roadsigns=0
[device]
[android]
fullscreen=1
tablet=1
asa incepe e ok?
